Rendering#
After a growing season is completed, gym-DSSAT provides a visualization interface both for raw state variables or rewards.
State#
To vizualise the time of state variables of a trajectory, you can call:
env.render(type='ts', # time series mode
feature_name_1='nstres', # mandatory first raw state variable, here the nitrogen stress factor (unitless)
feature_name_2='grnwt') # optional second raw state variable, here the grain weight (kg/ha)
Nitrogen stress (unitless) and grain yield (kg/ha) against Day Of Year (DOY)#
Hint
All variables in env._state
are available for rendering. You can find the list and agronomical meaning in gym environment’s yaml configuration file in the state
key.
Reward#
Raw reward#
For quick reward inspection, you can use:
env.render(type='reward') # plot reward time series (DOY for Day Of Year)
Reward for a single trajectory against Day Of Year (DOY)#
Cumulated reward#
Simply adding the cumsum=True
argument, you can visualize the (undiscounted) cumulated reward.
env.render(type='reward', cumsum=True) # if you want cumulated rewards
Cumulated reward for a single trajectory against Day Of Year (DOY)#
